02 Tahoe Engine & Transmission
Hey guys,
I have an 02 Tahoe LT 5.3L 2WD Flex Fuel. As I'm sure most here can relate I love my truck, so I want to keep it as long as I can. This means eventually I might need to replace or rebuild the engine and transmisison.
So out of curiosity, what transmission and engine would you guys recommend putting in the truck if you had to replace it? or would you rebuild it.
A while back I came across a thread were someone said I could get an engine from GM for cheaper than than rebuilding a used one, especially if you do a full rebuild. Is that accurate?
Also, is it possible or worth replacing a 5.3L with a 6.0L?
FWIW, I don't need to do anything right now. I'm just trying to learn so come the day I do, I know what to get.
Thanks guys, much appreciated
R.
Talk to chawkins... he just swapped his 4.8 with a 6.0 And is very happy!
the thread was '4.8 gets pulled thursday'
^that. Had a 6.0 in my '02 2500HD and in an '07 vmax. Both were great engines.
6.0's are great engines but not great on gas. i had a trans go in my 03 suburban at 110k and i replaced it was a brand new GM 4L60. drove it until 170k with no issues
probably better to get a trans that is built up... the 4L60 has some weak points
At minimum go with a 4L65E. I have the high output 6.0 getting 12 MPG in town. I paid $3000 out the door for my engine swap. That was for a LQ9 drop out with 33,000 miles on it and then all labor and dyno tuning
Sent from my DROID RAZR using Xparent Red Tapatalk 2
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
