High flyin H2
3/4TonYukonXL
I bet that driver had a $hi* eating grin on his face till he hit the deck - although I think he had a pretty good launch angle where all 4 wheels hit about the same time.
Maybe I'll mosey over to motortrend.com to see if there's video.
No video that I could find, but there was an extended write-up (relative to the mag article) of the cross-continent trip they took it on.  The text says no damage (at least visible).
At least he didn't do the old nose-dive like that poor sod (stupid sod in fact) did this summer w/ his rado, that everybody was talking about!  :jester:
Hmmm  I thought it was a Sierra  ???
Yeah, you might be right on that one, K1500.
Mostly what I remember is totaled relatively new GM truck (see that's what happens when you get into your da*n 40's  :cheers:  ).
