bigger tires
85wrangler
here is a couple of "not so good pics" Really like how it turned out. Didn't think 2.5" would make such a difference!
  • Replies 47
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 277 Guests (See full list)
