WDTV Live, OGM1 & iPhone 5 = Amazing!
Where is the best place to ground the unit? I got accessory power from under the dash, X14 pin 8, and grounded at pin 1. I am sharing the pin 8 power with my backup camera, and have a SPST switch on the WDTV. I grounded both my backup camera and WDTV to pin1.
I am getting a whine on Video input and WDTV on with the vehicle running, and increases with throttle.
Thanks
I had the same problem, for some reason you can't use the same ground as the camera. I ended up grounding to the metal frame that holds the code reader plug and it fixed the problem.
If you need a 3.5mm A/V cable to RCA adaptor to go from the Advent's 3.5mm female jack on the MediaLink pod to the AV cable from the WDTV, give this a try: http://www.amazon.com/gp/product/B0007V6JCK/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
One of my customers tried it and it works - you will also need 3 RCA barrel connectors (female-female) and you will need to swap red & yellow connections so it's hooked up like this:
W-W
R-Y
Y-R
Looks like a really really neat setup. However, I have a question. If the unit is connected to the input on my OGM-1, can I then send it to the headrest monitors? Most of this stuff would be really handy for showing youtube videos and movies on the backseat monitors.
Simple as using RCA "Y" adaptors to send signal to the headrests...
Hmm...That's very temping. I may have to look into performing this upgrade to my system. Then just get all my kids DVD's loaded onto flash drives. Thanks Walt! Great stuff as always!
Yeah, you really should look into it – it is BY FAR the biggest bang for the buck that you can get in car audio today and it allows you to play ALL of your digital media files instead of only the ones that the head unit manufacturers will allow you to play...
  • 5 months later...
Hi;
I was hoping you guys who have done this upgrade to the OGM1 can post photos of your install? I have a '12 Sierra, non-Bose, and I am having some trouble coming up with a suitable and painless place to install this. I have my media link pod installed in the empty cubby on the dash.
Thanks!
As a follow-up to my post, I decided to store the unit in the middle console on the floor under the middle seat. I ran the wires (power, A/V cable and USB extension) under the carpet and up behind the dash.
What I really need to know now is why do I have engine noise/an engine whine while using the WD TV? I attached the ground at one of the metal studs for the gas pedal (NOT my back-up camera ground) as recommended earlier in the post, but there is a lot of whine.
How did the other folks solve this? Another spot for ground? A noise filter?
Thank you in advance!
I tried just about every location I could find for ground under the drivers side dash and still have alternator noise on the WD TV Live input on the OGM-1. I bought an RCA noise filter which reduced the noise a lot, but the noise is still there.
Has anyone else solved this issue or something similar? I would love to nail down the cause for this noise!
Thank you!
Thank you!
This has been reported to work: http://www.amazon.com/gp/product/B002ZRQ3PW/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
