GMT 800 Parking Brake Adjustment
Does anyone have a procedure to adjust the parking brake on a GMT 800 1500? Disc hat (drum) looks good, pads are not really very worn, applying brake fully still holds the Suburban but the pedal has been going farther and farther down and it now goes all the way to the floor so I suspect that soon it will not hold the vehicle anymore. Is there an adjustment procedure for these?
Drives:'06 Suburban 1500 LTZ 6.0 3.73
Thanks for the PDF. I'll check it out. And yes, I had one of those in a previous vehicle, a parking brake that never worked that is. I'd like to keep this one alive if possible.
Rare burb
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
  • 2 months later...
Well it became time to do rear pads so while doing that job I took the rear rotors off and inspected the parking brake components. Everything looked good so here is what I did to successfully adjust the parking brake.
Remove rear rotor, find the star to adjust the shoes, figure out which way makes it expand the shoes apart and turn a few times until the rotor is hard to get reinstalled, remove the rotor, turn the adjuster the other way in small increments. When replacing the rotor, rotate it back and fort a bit and listen. When you can just turn the rotor without hearing rubbing, maybe loosen the adjuster just a touch more and reinstall the rotor.
This is what I did on both sides and now the parking brake travel is much less. I'm very pleased that I took the time to do this. I did not use and special tools or measure any clearances.
whats a GMT 800 mean ???
You know how a '99 GM full size truck or Suburban looks totally different than a '06 which is again different from a '07?
See this article. Especially in forums that cover multiple series in a single forum, the GMT series can be important.
http://en.m.wikipedia.org/wiki/GM_GMT_platform
no one uses that term for a truck at the dealers ,,,,,no one except here ,,,,,sigh ......
fail of the epic kind lol
I personally don't see the problem.....they are indeed GMT800 series trucks. You must be extremely bored to respond to a thread specifically because you don't like the terminology. Now put the keyboard down Rob and go drink yourself into a bloody stupor.
:cheers:
It's better than using OBS, NBS, NNBS, NNNNNNNNNNBBBBBSSSSSS :lol: like they use on other forums. I see 400, 800 or 900, I instantly know what body and years they are speaking of
No need at a dealer..... the vehicle is sitting in front of you.
Im not bored or drinking , sry you are upset by me playin around , have a good night ,
I was just messing w/ you myself Rob....didn't you see the "cheers" LOL....
