Northwest Indiana Connection to Terrorists
pacodiablo
Found out today from my mom that the fbi is doing some heavy investigation here in northwest indiana.  Munster indiana at community hospital.  Supposedly i dont know when but a man from afghanistan was checked into the hospital.  He was young and very malnourished.  A lady my mom works with (small company) said her daughter was one of his nurses.  She said when he would always close his door and go on his computer.  Very secretive.  Well he once told the nurse he didnt care if he was well or not he had to leave on this certain day to go to flight training school.  He was leaving no matter what.  There is a flight training school in lansing illinois not far from the hospital but i think it does only small planes.  Still to have possibly terrorists 10 miles from my home is scary.
Ill post a link tomorrow if it shows up in our local online newspaper
Man we had a scare here in southern West Virginia too.  I go to Concord College.  In Bluefield, which is about 10 miles south of us, there was an arab that went to Bluefield State and had his pilots liscense.  He dropped all his classes 5 days before the attacks and moved to Flordia, then no one could find him.  The FBI was up here on the 14th looking around and trying to find anything they could of his or about him.  It's was really scary to think there was one of them that close to here.
i talked to my mom today and she said that about 2 miles from my house this arab was arrested for all this stuff linked to bin ladin i seen it  on the news he had a store in burbank,il right down the street from me
It's really scary but it seems like they are every where. We may well find out how extensive they have infiltrated our country. I hope I don't get paranoid though.:sneek:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
