C0035 Fix?
Ok, i cleaned the sensor and reinstalled everyrhing. Cleared out the code and drove 10 miles home. Scanned it again but still pulled the same code. Now what?
have it diagnosed thats what ,,,heres the code service info for you ,,good luck
it didnt come out that well for some reason ,hope it makes sense
DTC C0035 or C0040
Circuit Description
As the wheels spin, each wheel speed sensor produces an AC signal. The
electronic brake control module (EBCM) uses the frequency of the AC signals to
calculate each wheel speed.
DTC Descriptors
This diagnostic procedure supports the following DTCs:
DTC C0035 Left Front Wheel Speed Sensor
Circuit
DTC C0040 Right Front Wheel Speed Sensor
Circuit
Conditions for Running the DTC
The ignition is
ON.
The vehicle speed is greater than 13 km/h
(8 mph).
Conditions for Setting the DTC
Any of the following occurrences may cause the DTC to set.
The EBCM detects an open or shorted wheel speed
sensor circuit for 500 milliseconds.
The EBCM detects the absence of a wheel speed
sensor signal for 5 seconds. If more than one absent wheel speed sensor signal
is detected, the condition must be present for 120 seconds to set
DTCs.
The EBCM detects an erratic wheel speed sensor
signal for 200 milliseconds.
Action Taken When the DTC Sets
The EBCM disables the ABS and may disable the
dynamic rear proportion (DRP) if more than one wheel speed sensor DTC is
set.
The ABS indicator turns
ON.
The brake warning indicator may turn
ON.
The actions above are maintained during subsequent ignition cycles until the
EBCM completes a power up self-test. This test concludes when the vehicle
achieves a speed greater than 13 km/h (8 mph) and the wheel speeds are verified
by the EBCM.
Conditions for Clearing the DTC
The Conditions for Setting the DTC are no longer present and you use the scan
tool Clear DTCs function.
Diagnostic Aids
Thoroughly inspect the EBCM ground, connections
or circuitry that may cause an intermittent malfunction. Refer to Testing for
Intermittent Conditions and Poor Connections
, Connector
Repairs
, Testing for
Electrical Intermittents
and to Wiring
Repairs
in Wiring Systems.
Inspect the following components listed below
that may cause the DTC to set:
Physical damage to encoder ring
teeth.
Debris on the wheel speed sensor or the encoder
ring
Inspect wheel speed sensor mounting
surface
Loose or improperly mounted
sensor
Air gap between the wheel speed sensor and the
encoder ring may be too large
Loose or worn wheel
bearing
Water intrusion in the wiring harness and/or
connector
If the customer's concern is that the ABS indicator is on only during humid
conditions such as rain, snow or vehicle wash, thoroughly inspect the wheel
speed sensor circuits for signs of water intrusion. Use the following procedure
in order to help isolate the problem area:
1.
Spray the suspected area with a 5 percent salt
water solution.
2.
Operate the vehicle at a speed greater than
13 km/h (8 mph) for at least 30 seconds.
Repair or replace the suspect harness if the DTC sets.
Step
Action
Values
Yes
No
Schematic
Reference:
Antilock Brake
System Schematics
Did you perform the Diagnostic System Check –
Vehicle?
Go to Step 2
Go to Diagnostic
System Check - Vehicle
in Vehicle DTC Information
2
1.
Use a scan tool in order to clear the
DTCs.
2.
Operate the vehicle at a speed greater than the specified
value.
Does the DTC set?
13 km/h (8 mph)
Go to Step 3
Go to Diagnostic Aids
3
1.
Turn OFF the ignition.
2.
Raise and support the vehicle. Refer to Lifting and
Jacking the Vehicle
in General Information.
3.
Disconnect the wheel speed sensor
connector.
4.
Use a DMM in order to measure the resistance across the wheel
speed sensor.
Does the resistance measure
within the specified range?
700–10,000 Ω
Go to Step 4
Go to Step 8
4
1.
Slowly spin the wheel by hand.
2.
Use a DMM in order to measure the A/C voltage across the wheel
speed sensor as the wheel spins.
Does the A/C
voltage measure greater than the specified value?
100 mV
Go to Step 5
Go to Step 8
5
Inspect for poor connections at the harness
connector of the wheel speed sensor. Refer to Testing for
and to Connector
Repairs
in Wiring Systems.
Did you find and correct the
condition?
Go to Step 10
Go to Step 6
6
1.
Disconnect from the electronic brake control module (EBCM), the
harness connector containing the wheel speed sensor
circuits.
2.
Test the wheel speed sensor circuits for the
following:
An open
A short to ground
A short to voltage
Shorted together
Refer to Circuit
Testing
and to Wiring
Repairs
in Wiring Systems.
condition?
Go to Step 10
Go to Step 7
7
Important:
Refer to Diagnostic Aids before replacing the EBCM.
Inspect for poor connections at the harness connector for the EBCM. Refer to
Testing for
and to Connector
Repairs
in Wiring Systems.
condition?
Go to Step 10
Go to Step 9
8
Replace the wheel speed sensor. Refer to Front Wheel
Speed Sensor Replacement
Did you complete the
replacement?
Go to Step 10
9
Replace the EBCM. Refer to Control Module
References
in Computer/Integrating Systems for replacement, setup and
programming.
Did you complete the replacement?
Go to Step 10
10
1.
Use the scan tool in order to clear the
DTCs.
2.
Operate the vehicle within the Conditions for Running the DTC as
specified in the supporting text.
Does the
DTC reset?
Go to Step 2
System OK
  • 4 years later...
  • 2 years later...
Question I literally just replaced the Left wheel hub less than 100 miles and my service code C0035 "left front Wheel speed sensor popped up shortly after" the reason why I Replaced it was because it was like locking up and making a horrible cracking noise, and once I replaced it, it was good as new/back to normal and now as I pulled into work it happened again. Should I replace the wheel up again since its still under warranty or should I take it in to get it properly diagnosed??? please help and thank you.
    Arva
    Arva
  • Who's Online   5 Members, 0 Anonymous, 577 Guests (See full list)
