How-To: Install LED Cargo Lighting.
Bought an Extang cover last week and I knew I was going to be forced to put some sort of lighting under there or make sure I kept a charged flashlight handy...the latter was not appealing to me.
Others have posted similar stuff, and I took portions of each of them, thanks to everyone for the great info. My install is below, hope you like it.
Cargo LED light install:
Materials:
(Purchased from Amazon.com)
HitLights Waterproof LED Flexible Cool White Lighting Strip, SMD3528, 300 LED, 5 Meter or 16 Ft, 24 Watt, 12 Volt
Omega Au46 Heavy Duty Mercury Car Alarm Car Cycle Tilt Switch
(Misc)
12 gauge copper strand wire- approx 25 ft
Heat shrink tubing
Electrical tape
Tools:
Phillips Screwdriver
Wire Strippers/Cutters
Torch/Heat Gun
8mm box wrench
8mm socket/ratchet
Torx screwdriver (tailgate cap removal)
I wanted to use a mercury type "tilt" switch for this, tailgate up=lights off, tailgate down=lights on!
Up
Down
I started by installing the led lights under the bed rail. It was cold, so I lightly heated up the metal with my butane torch. I started at the front and worked to the back. Lights are under the rail until about 8" from the front of the bed. I wanted to make sure the lights were really bright towards the front.
These lights are so easy, peel the backing off the 3M tape and stick!
Next up, the mercury switch.
I removed the tailgate cap, 4 torx on the front and the double sticky tape on the back. The switch comes with the mounting tab straight, for my install I needed to bend it approx 45 degrees.
I used the 3rd hole from the left of the tailgate, it's the round one, for the switch mounting. I used an 8mm, 3/4 long stainless steel bolt, 8mm nut, (2) 1" washers, 1/2" washer. The install is fairly simple, but if you have gorilla fingers like me it's hard not to drop the stuff down inside the tailgate. Put the bolt through the 1/2 washer, then through the switch mount, then through the 1" washer. Place the assembly through one of the bigger holes and CAREFULLY slide it over to the mounting hole. Place 1" washer over now through bolt, then the 8mm nut. Hand tighten, then use 8mm box wrench on the bolt head, 8mm socket on the outside to tighten.
Now, running the wires. I ran the switch wire out of the hole in the tailgate hinge mount since it was a little more finished and didn't have sharp edges.
I pulled power from the trailer wiring harness 12 volt constant, ground was from one of the bumper to frame bolts on the left side.
The rest of the wiring is pretty self explanatory. The positive from both strips were wired to the switch, switch wired to the 12 volt constant. The negative from both strips were wired together and a jumper wire pulled in the ground.
Disclaimer, don't run the wires near anything hot or anything that rotates and you should be fine. Use electrical tape and heat shrink on every splice and you'll be golden! For even better connection solder every joint. Also, wire loom everything possible.
Such a nice mod and I'm hoping it'll be enough light. If not, I'll add strips to my bed cover support rails, along with quick disconnects for taking the cover off.
  • 3 weeks later...
I think i'm going to have to try these lights, I already have a rocker switch and a fused power line coming in off a trailering power wire, but a buddy ripped his rucksack outta the back of my truck and took 1/2 my lights with it..
    • The part # is 84520447, mine does not have the cooled seats but I'm willing to possibly change the cover and foam if needed.   I tried that site and a few others,  added to cart and then paid. About an hout later I received a refund stating it has been discontinued.
    • Thought I would add to what Bruce answered, not only do the HD models use the torsion bar system, there are I believe 5 different torsion bar spring ratings that are all physically interchangeable with all the HD trucks going from a two wheel drive 2500 all the way up to the duramax or a gas engine truck with a snow plow prep package front end weight capacity that use the maximum sized torsion bar. It starts from a 4400 lb rated set in 400 lb increments up to 6000 lb. If one wants to fine tune the ride for a certain truck application they can swap out the torsion bars.
    • First off pay close attention to what Newdude pasted as he is a GM tech !.    I have a couple of questions which might cross off some questions others on this forum would be wondering about as well. So when was the engine oil changed prior to this trip, was it almost brand new oil or did it already have a fair bit of use on it before you started the trip.   Did you check the oil level on flat ground and was it at the full mark just before leaving on this trip which I gather from google map is about 700 miles or so. Why I ask and this is not the first time in history that has happened, that either a dealer or some other shop changed the oil on the vehicle and the vehicle left the shop and the owner ( you ) assumed the engine oil was full but in reality the person who changed the oil simply did not put enough oil into the engine .. it happens !. Also that a shop put the wrong viscosity oil in and an engine was not happy with that thinner viscosity and oil got past the rings at a higher rate than the proper viscosity. Not to mention if there was any leaking out of a drain plug or the filter gasket etc.
    • You could, although in the end it really doesn't make much difference what comes out in exact terms since it comes down to putting enough back in so that there is enough volume so that something flows back out once the trans is up to temp for the check procedure. I presume your putting a pan on that has a drain plug but its probably the same pan mold/size as at least a while back no extra volume pan was made for the gas truck version due to the exhaust cross over pipe issue. All I can say as per volume I put back in and this was based on changing out the filter as some is trapped in it that does not come out until its removed because of the way its made inside and my truck had sat over night with the trans having been hot when shut down and dripping internally before I pulled the pan. I went off of what the trans shop suggested as a minimum volume he found worked which was 9 1/2 quarts and I had enough flow out of the stand pipe that I knew I was right on the money once it slowed to a dribble and never wasted hardly any oil but it would be totally fine to throw in a full 10 quarts too. I guess personally I wouldn't ruin a perfectly good pan by drilling a hole in it, not with the cost of replacement pans up here or the dorman one anyway with the drain was 500.00 when I priced one out a while back, totally stupid.    I might not have said before but this trans oil type really expands with heat and I think its been said on this forum and the trans shop said the same so I wanted to try and hit the lower temp of the range vs at the top or go shooting above it as that would allow more oil to flow out which wouldn't be ideal.
    • Since I am going to be replacing the pan, I am just going to drill a hole in the original to drain it so I will be able to catch the fluid easier and measure how much I took out.
