Hey Sarah is that an Nfab light bar? I have some KC lights on the shelf that I'm thinking of putting back on be cool if I could get all 4 lights on it though
Sent while in 'Murica...
Yea me and a friend made the bar nfab is overpriced garbage compared to mine. And ryan It's wired to a trailer plug for easy removal which is wire to a relay and into a switch in cab
Alright I gotcha. Good thing my buddy works at a metal fabrication shop. We'll try whipping something up so I can get all my lights back on. Coming into the rut so deer crossing the road is gonna be more common.
Maybe the added light will be some extra protection for my 4am drive to work.
Do you have any specs for it or did yall just start bending metal? Lol
I want a set of these. Serious long range power. I like light bars up close, but IMO big bad ass dinner plate halogens can't be beat for long range.
http://www.myhellalights.com/index.php/default/auxiliary-lamps/halogen-lamps/rallye-1000-black-magic-series/
I have 4 KC daylighters pencil type beams. Between 4 of them the beams spread out pretty well
Fox 2.0 shocks and bds 6" lift springs on 2" blocks. My lift is half fts half bds
Next on the list is crank up front new idler arm and pitman arm and alignment
Edited by SarahsGMC
Let us know how they handle with a loaded trailer. That's what I'm waiting to see, cause I may either get the 1500 lift springs or spend the extra money to get the 2500hd lift springs
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
