I am looking to lower my 08 Sierra Denali AWD, and I was just wondering if anyone has any experience with this. I've heard changing the right height of an AWD truck may cause vibrations. I am thinking of doing a 2/4 inch drop. Anybody had any or know of any problems with this? Side note: My plans are to use lowering springs up front and drop shackles and block removal in the rear. Probably just going to run stock shocks if they will still fit.
Not sure about AWD, but there are a few 4x4 guys with 4/6 drops. Our body style of trucks sit up so darn high a 2 inch drop is almost unnoticeable.
I would recommend drop spindles vs. springs.
Edited by DoMDrty
PM NORCAL SS. He does a lot of drops. He does a lot of AWD Silverado SS's. Here is a link to his profile
http://www.gm-trucks.com/forums/user/110073-norcal-ss/
I see you have one post. You need to have I think 5 or 10 posts to PM someone. I sent him a PM on another site to look at this thread.
Edited by chawkins6789
The 4wd guys wouldn't have a problem with vibration because on the highway your front drive section is not engaged. On my AWD it is always engaged, so I am worried about what the change in pinion angles up front will do. I agree with you on the springs, also. I might even just go with the belltech adjustable struts up front, since i need new shocks and struts anyway, and keep the stock springs.
I edited my post. I hope he replies here. He has experience in lowering AWD trucks and Trailblazer SS's
ive done many of them
Front i would do belltech spindles and rear belltech sp shocks
then djm 4-5 inch flip kit
Any quetsions just holler i deal with both djm and belltech daily
Thanks, I don't know if you came because my message on silveradoss.com but Thanks for the help over here
no prob
You are the expert
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Would the belltech lowering struts work ok for the 2" drop in the front, or do I need to go with drop spindles to keep a good ride?
I want to do 2/4, but I already have 2" belltech drop schackles in the rear to level the truck. Just checking prices, my cheapest route is belltech lowing struts up front to lower it 2", just the leaf spring flip brackets to drop the rear 2 more inches (if I can get those by themselves), and then belltech sp shocks in the back. Then I will end up with a 2/4 drop and new belltech shocks front and rear. But I don't want to scrifice the ride if the lowering struts set to -2" are going to make the front to stiff.
Spindles wont screw your ride. The suspension remains the same. He knows what he is doing with AWD trucks. He does Silverado SS's and Trailblazer SS's all day long. I would go along with his suggestions and being a forum member he may cut you a little deal on it. A lot of guys on another forum I'm on buy their stuff from him
ok heres the issue with the trucks different ones used different front springs. Some of the trucks 07 up ive seen sit 3/4 inch higher than others due to the springs they used at the plant.
Heres what i do on all the kits i install before anything
1) measure from ground to fenderlip in rear
2) make sure you still have the lifting block in rear still in
Tell me that and I can dial in the exact kit you should go with. For 2 inches in front id roll the belltech spindles
Here is my new escalade 2.75 drop front (spindles and my custom strut mod) and rear cromoly control arms and beltech kit with djm swaybar no issues at all
ok, here's what I got. 36.5" in the front, 37.75" in the rear. I already have Belltech 2" drop shackles in the rear to level the truck (As you can see it really didnt level it). Ultimately, I want to end up with about a 2/4 drop with new struts and shocks front and rear (I still have the stock shocks and I have 115,000 on the truck). I am going to upsize my wheels to 22" with 285/45 tires, and I want to add a sway bar kit to the rear (belltech or DJM, whatever i can find a better deal on). I appreciate your help, Norcal. You seem like you know your stuff, and your trucks look Great!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
