Occasional stalling at idle...
I'm curious if anyone else is/or has experienced this with their GMT-800 series.
I have a 2004 Sierra with the 5.3L. It typically runs very reliably, but on occasions since I've owned it, it will develop a stumble when coming to a stop. This in turn triggers the low oil pressure warning and the truck shuts down and the alarm bell starts going off.
A quick throw into neutral and turning the key, and it will refire and I'm on my way. Still, it's really unnerving, especially in stop-and-go traffic.
This morning it acted up again, and stalled 4 or 5 times on me. I finally ended up just letting the truck roll over to the side of the road to get out of traffic. At that point, I turned the key completely off and removed it from the ignition. Then I let the truck sit for a couple minutes, before I restarted and merged back into traffic. After that, it was fine all the way to work.
My thinking is that it's a glitch with the drive-by-wire system, and by completely shutting down the truck the throttle body controller resets itself.
There's no TSB's that I can find related to this, so I'm wondering how common this is?
Have you cleaned the throttle body?
How many miles and what maintenance has been performed?
The truck currently has 101,000 miles on it. However, it's done this random stalling since I bought it back in 2005 when it only had 6,500 miles on it.
Last year, while it was at the dealer for some other service, I had them do a throttle body cleaning since it had never been done. Right after getting it back from the dealer, it acted up and stalled on me. I then did a second cleaning on the throttle body myself.
It will go for weeks with no trouble, then all of a sudden one day it will act up. Then the problem goes away and the truck runs fine for weeks again.
In past Google searches, I've come across a random post or two on other forums where people have had a similar issue (truck stumbling/stalling when slowing down or turning a corner – triggering the low oil pressure alarm), but with no real answer or solution.
No stored codes. I have a Scan Gauge II mounted above the rear view mirror to monitor coolant temp, trans temp, voltage and mph. It also has the ability to check for codes and clear the ECM.
The truck was just into the dealership for an unrelated problem (hybrid battery system code), and they reported no other codes. I also had them do a radiator flush, since it was due.
As a first step, I'll probably clean the throttle body this weekend and look it over.
Also, after doing some searching I came across a post on another forum where a GM Tech gave someone this answer:
"I have been fixing these trucks with this idle stumble and a/c inop. since the electronic throttle body came out on the trucks. The throttle body actuator is binding up and causing the unstable idle. I have tried cleaning them and so on with no luck. Replace the throttle body and gasket and take it to the dealer and have them update the pcm to also improve the idle stability."
Having worked on military aircraft for over 20 years I can tell you that intermittent problems are a pain in the a$$.....It would be better if it just shut down and stayed down. If you do get it fixed please come back and let us know what corrected it. Good luck...
One question though....after 7-8 years why are you so interested in fixing it now? LOL
You left out a ton of pertinent information in your op. You have the hybrid engine option on your vehicle which is quite bit different than the others. Your engine shuts off when stopped, then restarts when you want to move again. Does it have this problem when you disable the the auto-stop by running in tow haul? Have you had the dealer look into this?
Ever had the fuel pump replaced or tested, since the gmt 800 had a rash of bad pumps
I'd still remove the TB and clean it and check it. It's going to be dirty, if it has never been cleaned Might not clear your problem. I had a friend that had the same model and engine/hybrid. He had so much trouble with over the years as soon as warranty was gone he got rid of it
1) YES – the truck will do this even in tow-haul mode or with the windshield defroster on. Both modes disable the autostart/stop function of the hybrid system.
2) NO – I never had the dealer look into it. My thinking being that it happens so randomly, that most likely they won't be able to recreate the condition. Which means they'll say bring it back if it gets worse or if you get a hard failure.
3) NO – never had any issues with the fuel pump.
4) The throttle body has been cleaned by the dealer in the past – about a year ago. It stalled within days of getting it back from them. I checked it over for any loose clamps on the air intake and also cleaned the throttle body again while it was on the truck. The problem cleared up and it ran fine for a while.
Overall, my truck has been pretty reliable. This is the only nuisance item. Other people have reported the same problem with their non-hybrid GM trucks. Most responses on other sites range from "try cleaning the TB" to "the fuel pump might be bad" with no real answer as to the source of the problem. Mainly just people throwing parts and money at the problem hoping for a fix.
I'm leaning toward thinking it's a bug in the actuator on the throttle body. Just like the junk instrument clusters GM put in the 800 series with the low quality stepper motors that go bad.
One thing I'd check is the wiring at the TB. Check the wiring where it goes into the back of the plug. I know a friend that was having a similar problem and we discovered one of the wires had pulled out of the back of the plug slightly, making intermittent contact. Once this was repaired, no more complaints.
Reason I wondered if your problem occurred when locked out, I know at one time several of those vehicles needed to have the ECM re-flashed with updated programming
This is probably irrelevant information for you but it is free. The only vehicle I ever had that stalled sometimes when decelerating to a stop was a 94 Buick with the 5.7L LT1 engine. It was the EGR valve. What finally clued me to it was the fact that sometimes from a stop under very light acceleration it would stumble a little. This got me to thinking lean condition then to EGR which was the problem. I disassembled the EGR and it was carboned up. I had to do that about every 20K on the car.
That's a good suggestion on the wiring. I'll check the connection.
I remember reading not long after I bought the truck that GM had issued a software update. I'd have to check my records to see if that was ever done. I do know there is a TSB to change the oil pressure alarm reaction time on the hybrid autostart function from 2 seconds to 12 seconds. The reason being that on a hybrid restart, there's no RPM flare and the oil pressure takes a hair longer to build up. This can potentially trigger the low oil psi alarm.
My problem is definitely due to the idle stumbling when slowing down. When it happens, the RPM will dip below 500 and cause the oil psi to drop low enough to trigger the fail-safe.
Might look at this youtube video. He's getting "Reduced Engine Power" code. It'll give you an idea of what you're looking for
The link didn't show up in your reply.
Current update:
The truck ran fine today to and from work. However, while running some errands on the way home the truck stalled while pulling into a shopping center driveway. This time the "Battery Not Charging" message appeared on the DIC.
Putting it in neutral right away and trying to start the truck didn't work. It wouldn't turn over. I then put it in Park, turned off the ignition and tried again. The truck fired up and I was rolling. Then, while rolling into a parking space it stalled again and the Low Oil Pressure Alarm went off. I did my errand and it drove home fine from there.
So, tonight I do a search for the "Battery Not Charging" message and I found this:
http://www.gm-trucks.com/forums/topic/150665-aftermarket-devices-plugged-into-data-link-connector/?hl=%2Bbattery+%2Bnot+%2Bcharging
I'm now wondering if it isn't my Scan Gauge II that's the culprit of my intermittent stalling issue.
Have you had it place prior to your stalling problems? Disconnect and drive. Hopefully this is your problem and it will be solved
    • Pryme ! I was thinking of adding one to my 2024 6.6 gas  . Could you elaborate a bit more on your statement  Thank You
    • What a wonderful result! Great story telling to. You are quite multifaceted sir.  I'd keep it. Four is my limit too and yet we have five as well. One assigned the 'salt car' to do all those tasks you hate to ask of your 'Save for Good" crowd. 😉    Don't forget the antifreeze.    The Iron 4.3 is a favorite of mine.
    • Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
    • Happy 4th of July! Be safe out there tonight
