Ap3
jdelrizzle
Ok so my truck has the factory remote start, rpo code ap3 not ap8, remote start is already enabled, I bought a used truck and I was only given one key fob one key, I'm about to have some keys made and purchase some new key fobs (key fob kit). Now here's my million dollar question: Do I need to have the dealership program the new fobs to my truck? Or is activating them as easy as following the procedure in the owners manual? Once again my truck is already remote start enabled from the factory.
Should just have to follow the procedure. Just remember the keys have a chip in them.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Keys have a chip in them? So I probably have to through the dealer to get keys?
Or a locksmith, ebay etc.....
What year truck? Depending on that answer, you may not need a chipped key
Keys aren't cheap! My wife lost a set for her trailblazer a couple years ago.. they wanted like 100 bucks for one key at the dealer! Needless to say, we still only have one set haha. Got an extra key fob off ebay for like $15. programmed it myself but it didn't have remote start at the time. Just a series of key turns and button presses.
My truck is a 2009 it's not the one in my signature.post-104929-0-78624300-1363888219_thumb.jpg
I was just letting you know to get the correct key. They aren't cheap but locksmiths can still make them I believe
Then you need a chipped key. Dealer, locksmith for key, cutting and programming. Or ebay for the blank then get it cut.
What about the key fob, I don't need the dealer to program for me since my truck already has remote start, do I?
You should be able to follow the procedure in the OM to program your fobs.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
