Service Ride Control After Blowout
StevoDevo
Hi All,
I'm a new Yukon owner (2005 XL) and just had a blowout of my rear passenger side tire on the freeway. The tire was replaced, but now a Service Ride Control message has been showing on my dash.
What do I need to do about this? Is it that the sensor was damaged during the blowout? Who can I go to to get this looked at? I really don't like going to the dealer as I feel like they are just looking for an opportunity to rip you off!
Thanks!
-Steve
I can guess you used your spare which may or may not have a tpms inside. Sounds like it does not or Have you tried to relearn your tire sensors? Might give that a shot first.
How do you relearn your tire sensors?
Thanks for replying!
-Steve
Ride control has nothing to do with the tire sensors. The blowout might have damaged wiring to the shock on that side of your truck, maybe try inspecting the harness for any damage? I'm speculating on this but does this system need to be deactivated prior to changing a tire like the air suspension on old Caddys and Lincolns was? In the end I think you're going to need to have the code read and the standard scan tool is not likely going to be able to pull the code.
^^^^^^^ what he said ,,,you have to start a trusting relationship with the dealer ,,,have everything explained to you ,,, ,,,,tell them that
you have a code ,, but take a peak under for the busted wire to the level sensor first ,,,,no cost fix
No disable of the system is necessary to changing a tire.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
