2006 Fan Motor Resistor
Hey guys, I have a 2006 Sierra with Automatic temperature control. The fan is acting as if the fan motor resistor was not working, but I can't seem to find a regular looking resistor. All I can find is a board with a 3 wire connector and two hard wired to the motor.
What controls the fan speed in this truck? Is there a standard resistor board somewhere that I'm not seeing??
Thank you for any info!!
Nick
inspect the connector as well before ordering parts ,it has a tendency to melt,,,,the new connector comes with a foot of wires ,,,,,crimp each one at a time as all wires are white ,,,stagger the butt conectors so ya dont end up with a big wad of connectors all taped up
As said look at the connector. I have seen the resistor more often fail. But the connector can melt as well.
You will need a good 1/4 socket set with some universals and extensions it is a tricky removal.
I think they call it a module now.....doesn't look like the old style resistors. See attachment, item 2. After a little more digging, the manual systems still use what they call a resistor, the auto systems use the module.
HVAC.pdf
HVAC.pdf
HVAC.pdf
HVAC.pdf
correct, if u click on link i posted above, it is a module. fairly easy to change from what i remember. pop off the screws, pop down cover, and remove it.
splice in, your good to go.
    250.3k
    Danielustin
    Danielustin
  • Who's Online   2 Members, 0 Anonymous, 215 Guests (See full list)
