Random misfire - 8.1 104,000 miles
wakecumberland
I purchased a 2006 Suburban with the 8.1 about 2 months ago and it is throwing a random misfire code periodically. I get the flashing check enigine light any time I am unloaded and exceed aprox 65 mph and it usually occurs on the downside of a hill or rise. I also get the light around 50 mph when I am towing something. I do not sense a misfire and the truck seems to drive fine with no noticeable difference in engine revs or power before/during/after the light.
I have just changed the sprak plugs and wires and that did not solve the issue. I also tested the fuel pressure and it checked out. Where do I go next? Could it be an O2 sensor or something similar?
That code sends me into an angry frenzy ....
Not familiar with that particular engine at all, but on the 4.3 V6 that problem could be related to intake gaskets or the injection spider. No spider on that engine that I know of, so could be an injector issue, fuel pressure issue, ignition issue, vacuum leak, or intake gasket leak.
It might be the crank position sensor, on the 8.1 L engines they have had some issues with that sensor. It has caused some headaches.
Perform a crankshaft sensor variation relearn.
I know of 3 people with 2500 and this same problem. Each had the problem go away after doing this. One fella spent a lot of $$ replacing parts to no avail and it took a lot of persuasion to convince mechanics it could be this.
Sooooo, I went by my buddies shop yesterday and had a discussion about the misfire problem. He used his diagnostic scanner to relearn the cps. Took a whole two minutes. I then hit the hwy, cruised at 80 and no flashy da CEL! I went about 15 miles with no issue (knock on wood).
  • 2 months later...
Well the relearn did not fix the problem. The check engine light went away for a couple days but now its back to its old tricks again. Any other thoughts?
check the coil packs.. go thru the carwash and see if it starts missing I had that issue, Also watch the rear drivers side manifold bolt for exhaust leaking.
Car wash causes no problems. I would expect some specific cylinder misfires if it was a coil pack issue. How could I know whaich coil pack is bad?
How can I check to see if i have an exhaust manifold leak?
    • Mobil up another dime this am , $3.89, others will probably go up later. Any ideas on the reason for the increase other than greed? I've been working 14 hour days and haven't caught the news in a few days.
    • AMSOIL SS is about prevention and it is very good at it's job. I've never seen it claim to be a cleaner however like Valvoline R&P. Almost any oil that has some Ester or Alkylated Naphthalene in sufficient quantity will do a good job at keeping the rings functional.     I see the market splint among these types in two groups; those that use the same tech in every weight grade and those that reserve the tech for the EPA (EPA) friendly grades. Mobil 1 for example keeps the Advanced Clean chemistry out of the SAE 40 and up weights. Other like HPL (top shelf group and No-VII), Red Line HP, TORCO, MPT30K use the tech in all grades. Just not something the Wally World oils are into.
    • Max Trailering Package.  RPO code NHT.   includes 3500 HD Frame, 3500 HD Leaf Springs, 12" Rear axle and 3500 HD Shock Package.   GVWR goes to 11,750lbs for crew cab standard box 4x4, 11,900lbs for crew cab long box 4x4.  2WD crew standard is 11,500lbs, 11,550lbs crew long 2wd, and 11,450lbs on regular and double cab 4x4.       There is also NHT on 1 ton dually regular cab 2WD.  includes 3500 HD Frame, 3500 HD Leaf Springs, (F60) Heavy Duty Front Spring/Camper Package, 12" Rear axle, 3500 HD Shock Package, and Z6A Gooseneck / 5th Wheel Prep provisions with bed stamped holes and caps.  GVWR of 14,000lbs.
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
