parking assist module
casale33
2011 silverado crew cab,the park assist module was damaged under pass seat and i replaced it. code b101e/b1015 come up ,vin on module not matching bcm , whats the procedure/options for this , any help would be appreciated. its out of warranty, thanks
You probably have to get it reprogrammed at dealer with the tech 2. If the vin dosent match, it wont work.
  • 7 years later...
