JOTD: The Widow.
Bad Bowtie2
A widowed Jewish lady, still in good shape was sunbathing on a deserted beach in Boca Raton.
She looked up and noticed that a man her age, also in good shape, had walked up, placed his blanket on the sand near hers and began reading a book.
Smiling, she attempted to strike up a conversation with him. "How are you today?"
"Fine,thank you", he responded, and turned back to his book.
"I love the beach. Do you come here often?", she asked.
"First time since my wife passed away 2 years ago", He replied and turned back to his book.
"I'm sorry to hear that. My husband passed away 3 years ago and it is very lonely", she countered.
"Do you live around here?" she asked.
"Yes, I live over in Coral Springs" he answered, and again he resumed reading.
Trying to find a topic of common interesy, she persisted, "Do you like p#ssy cats?"
With that, the man dropped his book, came over to her blanket, tore off her swimsuit and gave her the most passionate lovemaking of her life!! When the cloud of sand began to settle, she gasped and asked the man, "How did you know that was what I wanted?"
The man replied, "HOW DID YOU KNOW MY NAME WAS KATZ?" :rollin:
Its slightly different on Silverado SS.com
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
