Chris' 04 Sierra 1500 Fun Daily Build
Chris
No I want to keep the batteries charged for the fridge to run on the 3 hour tow
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
  • Replies 699
On most of the diagrams I see online, they show an auxiliary pin and a 12V pin. I thought the big center pin was for if the trailer has backup lights. So that leaves you with two pins to try. Take a volt meter to the connectors on your truck while it is turned on (with light off and no blinkers and no brake applied) and see which pin has a constant 12V
As for the wire, I'm not sure if a 14 gauge wire is enough to carry that current to the batteries. Wonder if you could cram like a 8 or 10 gauge wire in the connector for more flow?
I believe its pre-wired. I just want it all to work properly. Everything does what it needs to do
I am guessing the 40 amp fuse goes where this red plug is
Haven't put in the fuse yet but it's mounted and plugged in
Check on your fuse box cover to where it goes. I have a different style fuse box, but it should be in approximately the same place
New bushings in, and with factory leafs and a 1.25" block my rear wheel wells sit right at 37"
They are being installed right now.
Springs are in, added 1/4" of height since I took the block out. So sitting at 37.25 inches in the rear
Good thing you got the black bushings. They supposably have something in them that help them self lubricate to keep from squeaking as much. The red ones are just for show (I just got red to match shock covers)
I got what was in stock at the time.
Old springs look a little flattened
They have been riding on the overload for a while
New springs in
And how it sits now
Blower, brakes, cam, stall, built tranny, 3.73's with a true trac, and minor appearance changes as I get bored. This is all as budget allows.
I got a deal on the springs and ended up cheaper than air bags.
Regear and Hydroboost are next on the list. then 05+ front brakes and SUV 2 piston rears. Too cheap to go Big Brake kit right now
I would sell you my rear end when I regear my other axle housing, but I'm all the way over here on the east coast. So if your ever over here, give me a holler! :lol:
I want to put in an LQ4/ LQ9 with heads, cam, built internals, a bit higher stall, and either a roots blower or a twin screw blower (if I can find one for my model year).
I just ordered some braided stainless brake lines, so hopefully that will help a little bit with stopping these heavy tires.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
