Chris' 04 Sierra 1500 Fun Daily Build
Chris
the week before i traded my truck in i did a bunch of burnouts because the tires were already bald and i could see cords on both rears
  • Replies 699
I don't try to do them, but it happens. the driveway is concrete and steep. It will probably be after the Hydroboost when I do them and I will most likely do 2 at a time
I need to save money though
Very hard to do when 'ya like to play hard & go fast.....
Yes it is but minor things get in the way, need a nee cat, knock sensors, and tires
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Yes it is but minor things get in the way, need a nee cat, knock sensors, and tires Sent from my Samsung GS4 using Xparent Red Tapatalk 2
I know what you mean bud.
I may go with some Goodyears next for tires. Not bad on price and I will be going to 22's soon so they will just hold me over
You and your engine covers. :lol:
I'd keep the 20's and get quality tires. I'm never having another set of Goodyears, especially anything not 10 ply. Can you get 22's in E?
Probably can, Your truck came with 20's so I would say factory was the LS2 tire. I will not be going with those. Problem with my 20's is I curbed the hell out of 1 or 2 of them. I am also bored with the look of it right now. With the new manifold I need the GMT-900 engine cover or the TBSS cover for it. My current ones won't work
I should have kept the limited edition 20's, you could have bought them. :lol: I don't know what tires it came with, it was on its second set when I got it. They were Goodyears though. And it would spin them as easily as the 255 Goodyears I had, always a smokeshow in the rain.
You could always ditch the cover and show off the goodies.
Had to be the LS2's
Love your truck, man! I just bought the Volant CAI. I'm interested in your thoughts on it. Did you run the 6.0 with the stock intake, and was there a noticeable difference?
It will be close but my one wheel peels have taken a toll even with rotations
Aaaand you want another g80...oohhh Lordy LOL.
Post good burnout vid before tire swap!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
