sagent Posted June 27, 2013 Posted June 27, 2013 Spent about an hour last night trying to figure out how these will fit on my 2003 Yukon. Has anyone installed these before, they are the 2 piece ones that do not require pulling the axles The problem I am encountering is the arm for the e-brake cable does not seem to fit. My old ones were so deteriorated so I have nothing to compare to. Thanks
CapitalTruck Posted June 28, 2013 Posted June 28, 2013 What was price diff between Dorman and OEM? Might just return and get the real deal.
txab Posted June 28, 2013 Posted June 28, 2013 Spent about an hour last night trying to figure out how these will fit on my 2003 Yukon. Has anyone installed these before, they are the 2 piece ones that do not require pulling the axles The problem I am encountering is the arm for the e-brake cable does not seem to fit. My old ones were so deteriorated so I have nothing to compare to. Thanks I haven't had a problem when replacing them.
sagent Posted June 28, 2013 Author Posted June 28, 2013 Finally got them to fit right. However after putting rotors back on they are coming in contact with the inside edge of the rotor and making a screeching noise. I think I should have gone with the 1 piece as it seems what is rubbing against the rotor is the edge where the two pieces mate I did not price the dealer. They were about 40 bucks at o'reillys
txab Posted June 28, 2013 Posted June 28, 2013 I don't even know if the dealer would have a 2 piece. Should be plenty of clearance between the rotor face and the plate
Vortec-Z71 Posted June 28, 2013 Posted June 28, 2013 I remember doing these a while back. You have to pull the axle shafts with the GM ones which is not worth it. That's why I went with the Dorman 2-piece. If I remember correctly, they didn't install identical to the way the stock ones did. I spent a while trying to figure out how they went on because I was having fitment issues. I'll try to grab some pics in the next day or so if you still can't figure it out.
CapitalTruck Posted June 28, 2013 Posted June 28, 2013 Pulling axle...yuck. I understand your choice now.
