WINDOW MOTORS AND MIRROR
I have a 2000 Silverado LS three door version; I have replaced the drivers side and passenger side widow motor and still the one on the drivers side will not work. I also took the switch from the drivers side and plugged into the passenger side and it operated that side fine; the drivers side motor also operates on the passenger side. So this eliminates the motor or switch being bad. What could this problem be and how do I resolve this issue? HELLLLLLP PLEASE; IT'S HOT!!!!
Check your wiring for breaks, especially where the wire goes between the cab and door
hi midgamarine
you have need to diagnose a problem check regulator,wiring or switch on driver side.it is very helpful to prevent anywhere from theft.if you are unable to find out problem go to mechanic for repair.you may extend the life of window motor by giving proper maintenance.
  • 3 weeks later...
