It's here! Brotherlaw just called me, taking his morning walk and saw them unloading my truck. Here I am stuck at work. Ordered it 5 weeks ago yesterday. Pretty quick i quess. Be next week till I get it. Quess where I'm headed after work?
I hope mine comes in that quickly. Where are you from drs?
South of St. Louis Mo.
I think it was unloaded from a rail car at the Wentzville plant (about 2 hours north of me) then trucked down. Not 100% sure.
Edited by DRS 95 Silverado
I'm all the way up in new Hampshire so I'm sure the shipping process will be quite a bit longer. It's tough being patient.
Picked mine up yesterday. Came in last Sat. Was on dealers lot 5 weeks and 1 day from when I ordered it. Now lets all have good luck with them.
Very nice, I like the mud flags that you have installed, can you tell me are they from GM? Thanks
Yes they installed them at the dealer. I have a 1/2 mile of unpaved road to my house so I figured I better get them.
Well my truck was delivered to the dealership last night. They still have to get the wheels put on and get it washed and inspected. Here's a few pics of what she looks like now. I'm sorry about the crappy pics it was getting dark...
Sent from my SCH-I535 using Tapatalk 2
Nice, good luck with it. I wonder what they do with the steel wheels and tires they shipped it with? Do they send them back to factory to use again?
I wondered the same thing about the steelies. The tires are going on my 22's though. They said that they had to go to shipping the trucks with the steelies because people were jumping on the trains and stealing the 22's. So now they just ship the 22's to the dealership and they swap out the rims...
I am going to ask them if I can have the steelies though...
Edited by BringTheRain403
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
