Aftermarket Brake Controller
Personal preference I guess. I wouldn't want electric brakes going into water. Just sayin...
Sent from my SCH-I535 using Tapatalk 2
  • Replies 160
Just called the dealer today along with e-trailer who sells brake controllers and both of them told me there is a wiring harness under the dash, looked every where and every piece of wiring plugs into something, no loose wiring, some one has their head up their a@$. I think someone is confussed with the 13's.I use to install brake controllers 15 years ago so I think I wouldn't have a problem finding wiring.
Tekonsha already lists a pigtail on their site for their controller for all the 2014 models with a connector at both ends and it also says that drilling is required to install it.
added a factory controler cost 78.00 comes with n new benzel ez to put in,i was hoping for it to plug and play wireing harnes was up there . i talked to 3 dealers and they cant find out how to update the computer but are working on it. i think it is to new still and they have to work it out . i will re post when we get it worked out the DIC does not see it yet. i think it will have to be reprogramed.
2014 LTZ Z71 4X4 great truck
I think you're going to find it very expensive to add a factory controller. You will probably need a new ebcm, trailer brake relay, wiring harness and probably more. It will not likely be as simple as adding the control part and re programming. I did one on a 2008 and we finally made it work but cost upward of $800 and a lot of time and headache.
Glad you found that. From the instructions on the website it looks like it should be just plug and play. Much easier than adding a factory controller and having to reprogram the DIC and God knows what else.
I called Tekonsha a couple of days ago (their website list a part number 3016 wiring harness) to find out where I can get their wiring harness, they told me it is still in development.
I look forward to seeing how this goes. I plan to follow in your footsteps with this if you are able to find a means to an end. Thanks for being the pioneer.
I plan on weating about a month longer to give the tecks at the dealer to get togather and then i will tke it backand seeif thay have a plan to intergrate the factory controler to program that i purched from a gmc dealer I will let you guys know what hapends.parts only cost around 78 bucks pig tail is write behind where it goes and was pluged in to bland den on factory benzel.
Hopping for the best 2014 ltz z71 great truck Andy
GM has used the same exact plug for years. They just like to change around the configuration. The plug U-Haul sells has a red wire lock so you can change the wiring around in the brown socket. I am interested to see if the plug stays the same again.
    jgaudet99
    jgaudet99
  • Who's Online   0 Members, 0 Anonymous, 437 Guests (See full list)
