Advise on 2004 GMC Sierra purchase
.... new radiators are relatively inexpensive, so why bother?
True, but heater cores are not.
I do agree flushing isn't necessary (with the trans, either),
Re: coolant, I take the lazy approach & buy several gal.s distilled water ($0.99 ea). Drain, fill with same. Drive for a day, repeat as necessary. Drain, fill with DexCool.
So you run with just straight distilled water, with no coolant/dexcool at all?
Seems dangerous, no?
No no no, pls read last sentence.
(And yes, of course I do this procedure in above freezing temps)
Just dropping the trans pan will only remove 1/2 of the OLD fluid. That is why I suggested it, to keep some of the old fluid & worn clutch linning material in the fluid. The Sea Foam conditioner will also help keep internals clean & help seals too.....
  • 3 weeks later...
