himthere Posted August 26, 2013 Posted August 26, 2013 I can't seem to find exactly which model my 03 sonoma is. Need rotors and it seems model is important to get the right ones. The only indication on the body is the "Wheels" emblem on the tailgate and front fenders. There is a "SRS" molded into the steering wheel airbag. Looking up parts, there is no "SRS". The only models listed are "SL", and "SLS". I have a regular cab, not extended or crew. 2 wheel drive. 2.2 L engine. Rear drum, front disc brakes. Bolt pattern seems to be an issue also. Some rotors list as 5x4.75, and some as 5x4.80. Mine measure 4.5 center to center across the wheel, not adjacent. What method is used to determine bolt pattern? Can model be deciphered from the VIN ?
mofo1o1 Posted August 31, 2013 Posted August 31, 2013 you should be able to just run the vin to the dealer and they will tell you
Chris Posted August 31, 2013 Posted August 31, 2013 Model can be pulled from VIN and your options tag in the glove box. SRS isn't a trim level, it stands for Self-Inflated Restraint System. It is just the airbag and lets you know it is an airbag.
ClutchDisc Posted November 19, 2013 Posted November 19, 2013 Model can be pulled from VIN and your options tag in the glove box. SRS isn't a trim level, it stands for Self-Inflated Restraint System. It is just the airbag and lets you know it is an airbag. Is that what SRS means? I always thought it stood for Supplementary Restraint System.
Chris Posted November 19, 2013 Posted November 19, 2013 Could be yours. Who knows. Its too early in tha am. Its airbag stuff. Anyways it isnt a trim Sent from my Samsung Galaxy S4 using Tapatalk Pro
ClutchDisc Posted November 19, 2013 Posted November 19, 2013 Don't the Sonomas have the trim level on the B pillar like the S-10s do? Unless it's a base model, I don't think the base model says anything there.
RyanbabZ71 Posted November 19, 2013 Posted November 19, 2013 Sounds like an SL. My grandpa had a similar 94 Ryan
2002GMCSONOMA Posted March 18, 2014 Posted March 18, 2014 Sounds to me like its probably an SL model but he def. needs to run the V.I.N. to be sure.
