High-speed vibration
Hello, I'm hoping someone can help me find a vibration in my 2008 Yukon XL SLT, 1500 4x4, 5.3L, 120,000 miles. I'm having trouble finding a vibration at highway speeds. Above 70 mph, I get a loud, low hum that stays the same regardless of speed, above 70, or whether my foot is on the accelerator or not. As soon as I drop down below 70 mph, the hum stops and everything is fine. I started noticing this after I took it to my dealer for a check engine light. The dealer replaced the purge valve above the spare tire. While it was there, I also had all of the lubricants and belts replaced. I mentioned that I'm going on a road trip soon. The dealer said he'd do a comprehensive inspection. He didn't mention any problems after the inspection.
I've also had the tires rotated and balanced and I replaced the rear brake pads and rotors. It needed brakes anyway. None of that changed anything. The hum sounds like it's in the rear of the vehicle. I had my son sit on the floor in the back while I was driving and he said he could feel the vibration. I can't feel anything in the front. I feel nothing at the steering wheel.
I can take it back to the dealer and ask about it since it seems to have started after the last service. If it's something easy, though, I'd prefer to just fix it and save another trip, loaner car, etc.
I'd appreciate any ideas.
Thanks.
If it were my rig, I would pull the driveshaft and check the u-joints.
Replace the u-joints , and double check the rear end fluid level.
This is just weird. I thought something happened at the dealer during my last visit that may have caused the vibration. That wasn't it. A day or so after the service, I removed the rear seat so that I could shampoo some deer blood out of the carpet :-D. I didn't mention anything about the seat because I didn't think it would matter. It did! I put the seat back and went for a drive today. The vibration is completely gone. I took it up to 80 mph and everything was completely quiet. I guess I was getting some kind of harmonic vibration in the floor without the seat. Perhaps something is beginning to fail and the vibration is just too small to notice with the seat in. Either way, it's too small to worry about for now. I'm guessing I could spend a lot of money trying to find the problem. I'll wait until something really breaks.
Thanks for the suggestions.
Really? Make sure the spare tire is aired up to spec and winched up tightly against the frame.
The spare tire was the first thing I checked. I knew the dealer replaced the purge valve so I knew he had to move the spare tire to do that. The spare is solid. I also thought maybe it was the heat shield that keeps exhaust heat off of the spare. That's solid, too.
That's weird. I've never heard of noise caused by the rear seat being removed in the Yukon XL/Suburban of any generation. I know it's a different generation but we pull the rear row out of my wife's 2005 Yukon XL whenever we go on vacation and I've never heard a difference. I still wonder what's making noise that you can't hear with the seat in. Keep us posted if you ever find the culprit. I'd probably do the same as you and not worry about it for now since you can't hear it with the rear row in.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
