2005 GMC sierra 4wd problem
melanie33
My 2005 GMC sierra truck indicator came on saying service 4wd. When I try to change from 2wd to either 4wd hi or low it doesn't the light stays on 4wd hi even if the other buttons are pushed. If I start to drive it only kickes in 4wd hi if I accelerate while turning the wheel, if I coast while turning it doesn't it stays in 2wd even though the light stays lit on 4wd hi I can feel its not. Any suggestions on fixing this mess?
Agree that the OBDII code will hopefully tell the story. You will need 4WD to explore the Jemez this winter. I do miss living in Rio Rancho and having 10 billion acres of backyard to explore.
A standard scanner will not read that code
What about a Tech-2 with a CAN interface? As long as you have the software? Thanks.... cause I was thinking of getting one for my 2007.
Yes a Tech 2 can read them with the CAN interface. I was looking into one for the Sierra, Rainier, and the G6. A CAN interface is needed for the G6
I misspoke, you do not need the CAN interface for your 07 classic, The GMT-900 needs it and anything else that has had a body change after 06
Your description really fits a scenario for the dashboard 4WD switch being bad. I found a video about 4WD switch problems being a large percentage of the root cause of 4WD Service lights. It has the procedure for checking the impedance of the various switch positions. Might save you some $$$$. Just need a multimeter. I think it's worth a try before going to the dealership. You can find the video under you tube user "MAY03LT"
That issue was something about poor soldering
Sent from my Samsung Galaxy S4 using Tapatalk 4
