The Transmission
I know these trans are supposed to be adaptive and "learn" I have 1500 miles now... the trans has gotten a little better, but I'm still having trouble getting used to the grade/exhaust brake and the fact these trucks don't free roll as much as the old ones.
Even when I turn off grade brake... it seems the same. It reminds me of an old manual trans.. when you would down shift during slow down.
Again, I have 1500 miles... will the trans continue to improve?
i also noticed a few times... when the truck shifts from 2nd to 3rd ( or maybe it's from 1st to 2nd) it revs up right during the end of the shift. Anyone else notice this?
I have a 2 wheel drive double cab with 3.08 gears that does not rev between 2nd and 3rd gear, but I test drove a 2 wheel drive crew cab that did rev between 2nd and 3rd. It was an obvious rev and worriesome. I think the crew cab I drove had 3.08's but I can't swear to it.
My double cab now has 1800 miles on it and I can say that the transmission shifting and general performance of the truck has improved. It doesn't bog as much between gears as it did new, and it shifts a bit later and smoother now. When I first got it, it was really quick to shift up in gears causing the truck to bog.
One more comment, I think the variable valve timing is the biggest problem. I idle around all day while working out of my truck. When I leave work and need the truck to get up and go on the highway, it seems to have adapted to idling around all day and doesn't want to go. After i drive on the highway a while it "adapts" and runs great.
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
