Back in a GM truck(pics of my lifted 2014 Sierra)
  • Replies 91
Wow that's a lot of pressure. Are you running 35's?
The tires call for 80 psi on the side wall when using max load.
Lol. Sure buddy. I was just wondering if somehow my blue C6 was reflecting sonwhere in my pic.
hey Ive been having a problem with my pro comp lift and wanted to see if anyone out there has had similar problems/ experiences. I have a '14 and recently installed the pro comp 6" lift and other than a bit stiffer ride I like it. Definitely a bit slower with less MPG but i guess thats to be expected, what really is worrying me is the bad noises and vibrations I am getting in 4Hi and Auto4, I cannot positively say its due to the lift having never used the 4wd before the snow hit (after lift was installed) but at speeds over 45 I am getting some bad vibraions from the front of the truck, bad noises too. goes away the second I switch to 2hi, what are your experiences with your lift and 4wd?? Thanks much for any help?
I have not heard any noise from mine in 4WD but I do have a horrible vibration at anything over 65 mph. I think that has more to do with the junk pro comp tires the dealer put on the truck but other than that I haven't had any issues.
Mine is a much smaller lift with 34 inch tires. No vibrations or noises whatsoever. I've only had it in 4wd up to 65mph, but in 2wd up to 95mph.
What tires are you running?
any play in your CV axles? I have some rotational play, not alot but some and some side to side play, didnt think there is supposed to be any....
THANKS
