Rear main seal
sahls01gmc
How difficult on a scale of 1-10 is it to replace the rear main seal on my truck? To me, it seems pretty straight forward. Unbolt transmission, replace seal, bolt transmission. Obviously, other steps apply, but is there really more to it than that?
Does anyone have any tips to offer when tackling this?
Any help is greatly appreciated!
have you ever done anything like this before ?,im guessing not by your questions
its not a first time job to do ,,,,,especially on a garage floor ,,,
you should rethink it
I've pulled the engine on my old FWD car back in High School many times. I've had to do it to replace the engine, the clutch, the transmission...and even the water pump. I'm very comfortable with tools. I'm just curious what pointers anyone has from ones that have done it on these trucks. Sorry I didn't give you the comfy cozy feeling up front. No, I'm not ASE certified or anything, but I do know my way around under the hood if you know what I mean.
I do appreciate the feedback, it gives me some idea of what to expect.
Thank you!
You might as well do other items in the vicinity while you're there.
Mine was done in 2011 when the trans was replaced, so you might want to wait until that is needed.
I wish I had replaced the trans mounts then and a few other items.
  • 3 weeks later...
This is a smart suggestion
  • 5 weeks later...
What items in the vicinity do you suggest? I was hoping to wait until Spring, but it is now puking oil so I can no longer hold off. Probably going to tackle it this weekend. I will look at my malfuntcioning Transfer Case Shifter Motor while I have it all down.
How often should I replace the u-joints on the driveshaft? I changed them at 125,000 when they started squeaking. I'm at 255,000 now. They are not squeaking, but perhaps waiting for them to squeak is not a wise decision.
Thanks to everyone for the tips and suggestions!
A guy at work mentioned the excessive oil could be caused by a PCV problem. Any merit to that claim? I suppose I should change that anyways since it is a $2 part.... But would a bad PCV valve cause this? Obviously a seal was the weakest point, but was there an increase in crankcase pressure to cause it to fail?
Recently had this rear seal replacement done on a 2009 5.3 (under 100k so warranty item) it took the dealership 2 days and they had parts scattered all over the shop. They were also replacing the oxy sensor but it was seized in the pipe and they bent the line trying to get it out so they also replaced the y joint pipe with the catalytic converter. I thought when I heard about the extra parts that it could just as easily have happened to me if I were doing the job myself. Then of course after studying on that for a while I immediately traded that succa in on a 2014 like a good little consumer is supposed to. So Sahls01gmc have you driven one of the 2014's yet? Come on man GM needs the sales LOL Seriously though you should check the oil sending unit before you pull the tranny I believe it is towards the back of the engine and if it leaks can easily be misdiagnosed as a rear main leak so I have had heard..................
Thanks Dnt! I have not driven a new one yet, but they do look pretty sexy. I'm spending WAY LESS a month keeping this one running vs a truck payment, so I'm gonna keep it this way for a while. I've thought about the oil sending unit, are you saying the oil pump? Just making sure we're talking the same language. That would be an easier repair.
This did happen the other day. When taking off from a light (not launching, just normal take off) the transmission ( or so I think) almost seemed to mimic a blow off valve sound when it shifted into 2nd. The first time it happenned I thought it was the car next to me or something else because I wasn't expecting to hear that. It did happen one other time a day or two later. No other weird shifts or any other vibrations, just those 2 instances. Any thoughts what this could be?
Huge thanks to everyone's input and help along the way.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,290 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
