Thanks!!
Sent from my SAMSUNG-SM-N910A using Tapatalk
Installed my 30" single row behind the grill yesterday. I need to get some pictures of the finished product with everything back on and the light on, etc. but you get the picture.
Looking to do something similar on my Sierra hd. Have you noticed any increased temps?
Sent from my LGLS990 using Tapatalk
None at all. The radiator still gets plenty of air flow. As you can see in the pic, the AT grill is vented so even with that one gap covered up, still plenty of air getting to the radiator.
Thanks...got any night pics?
Well if you look back a page, you'll see that I swapped out the single row for a double row light bar. The single row wasn't as bright as I thought it would be. I am going to take some output pictures of the new one this weekend and post them up.
Here's what I've got from the single row.
55W 5000K Hid Lows
High's
Lows and Light Bar
Looks like the lows with bar are about the same as the highs by themselves? Thank you!
Edited by calgator73
It appears so in the picture yes, but I can tell you the light bar puts out much more light than the headlights do. These were taken with my iPhone so not the best pictures.
I will say that the new bar I installed completely blows this one out of the water.
I have a few questions. I am going to install the e30 ridged spot/combo a/w. I do not want to cut into my dash so my alternatives:
wireless or garage door opener link with the wireless connection or install a switch in one of the cigarette outlets in the center consol.
1. Being the bar switches from white to amber will the wireless remote work.
2. If I link it to the Intel link garage door button will it work maybe push once white push a second Amber third off. I'm asking I have no idea.
3. I read someone doing the cig lighter center console install has anyone else. Wonder how extensive or a pain it is.
Any insight would be greatly appreciated.
Adding the final touches... I ordered it from Steve www.sneveysoffroad.com 20inch highlander trail series with the combo beam. The install wasnt as bad as i planned till wiring the relay and switch.. Finished product evynybev.jpg Removing grill was a BITCH... Be prepared to cuss and drink like a fish. Step one.. Open hood. Pull tabs out that hold the plastic overlay. Than there is 4x 10mm screws. Take those out... Next go in the wheel well take 2x 7or 8mm screws out. (this holds the painted peice above your bumper on) pull edges off till it reaches headlights. Now.. Slide under the head first under the bumper.. Above license plate there is painted to match clips push them with a flat head and wrap end of painted peice... There is 4x more bolts on bottom of grill a9umy4u8.jpgbyve8uje.jpg6aqu6e3a.jpg Now i used a dremel to cut slots for the mounting arm here apu8avut.jpg Drilled holes and mounted.. Perfectly LET THERE BE LIGHT!! THE ehare5uj.jpgyqahudub.jpg High beams and fogs.. (did that to) any3upa2.jpg You can compare that to just light bar. Heres all together su9u5ere.jpg Now the best part... I'm not drilling into a 40k trucks interior... Chevy made my dah here. I just pushed my toggled switch into here.. Holds Extremely tight.. Ran wires under panel under steering wheel out the hood popper. ydu7azub.jpg3ega8e9y.jpg
has anybody put a light bar behind a LTZ model?
This is post #1 in this thread. Idk if that helps you at all.
that's a LT grill.. I think if I get a light bar behind the grill, I don't think you would see that much light come through.
Edited by Willie will
What does your grill look like? I'm pretty sure I've seen a light bar behind just about every silverado/sierra when I was doing research for mine.
    Chris80s
    Chris80s
  • Who's Online   4 Members, 1 Anonymous, 688 Guests (See full list)
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
