New Laptop, suggestions.
STINSAN3
How many gigs of music, pics, videos do you have? You may want to consider a 60-80 gig SSD for the OS and programs and an external HDD for the pics and music. Mine will turn on cold and boot into windows and open up anything in under 10 seconds. It takes 1,300 watts to power it
That is a lot of power to run a computer. You must have a built gaming rig. Ive seen dual video cards with an i7 running on less power
  • Replies 96
Oh yes. I run an 8 core cpu with 13 case fans, watercooled ram/cpu, 7970, asus st, SSD. The thing really sucks up the juice
I really didn't lose too much, 20-40 high def photos of my truck.
All my bookmarks on websites and such. I did love my C6 Z06 background, though.
Definitely gonna get another laptop, thing lasted over 6 years.
You only have a single GPU and you're using a 1300w PSU? lol and I thought I liked overkill :)
With my abuse, mine last me about 3 years. But i travel a lot with mine
Is it sad that I still haven't got one yet?
Plus, my Dell actually did die couple of months ago. I think the whole motherboard is wasted.
As for now, using my grandmothers HP laptop, its a lower base model, My Dell was a better laptop then I'm using right now.
Forgot to reply to the actual thing I wanted to.
No it isn't sad. I've needed a new laptop for probably 2 years now and I still haven't gotten one yet. Even with an SSD the laptop is still somewhat slow, the fact that it's falling apart doesn't help either. I've just used my phone or tablet when I needed something while away from my desktop.
I am overclocked very high on my gpu, cpu, ram and my north and south bridge chipsets. Trust me i use about 90% of that 1300
That seems like a fair price.
Thats what I was thinking too.
Also, couple of my friends has iMacs and they love them.
I looked at MacBook Pro in 15" and its $2k....shewwww.
You will be very happy with an i7 1TB. and the windows 7 is a plus!
Gotcha, what would you recommend me?
The one you posted earlier in the link. Do you use RJ11? If so you will need that connector
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 701 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
