New Laptop, suggestions.
STINSAN3
Well went to my Moms yesterday and I got a new laptop, wasn't expecting that for Christmas.
So, I don't have to worry about buying one now! Even though I wanted a Macbook, they got me a Dell laptop that I like a lot. Even though it has Windows 8.1. Guess I can't be too picky, huh? haha
You could still put windows 7 on it.
  • Replies 96
How?
Purchase the FULL version of it on the dvd - be sure to install the proper bit and just format the HDD and install it. You will have to boot into the bios and set it to boot from the disk drive. Then you simply install the disks that came WITH the laptop which are usually drivers. If the disks do not have drivers simply go into the devices page in settings and look up the model of the components and search online for drivers for the NIC, video card, sound card, and the input controls, then save them to a usb to install on the new os. It is very easy i have done it many times. Also you can do a partition like 50/50 so you can have both OS's and get a choice on which one you want to boot from every time you turn the system on.
Or brick your USB ports like kstruckcountry did
Thank you, but I didn't get any discs that came with this unit. Just the laptop and the charging adapter.
Whats that mean?
If its an ssd be very careful. Make sure to disable auto defrag and dont format the ssd more than a couple times. It prematurely wears down sectors of the drive which hurt the drive and lower performance, this is because they were not designed to work that way. Slowly you will see it slow down and it will in your windows rating
Whats that mean?
I have no idea.... Maybe put the os on a usb
He put win 7 on a computer and a driver rendered the USB ports useless
Then go to the devices page and write down the name and info of the devices so you can download them online to a usb for the new os
Maybe he needs to roll back a driver or reflash the bios. Possible bad chipset driver also
Alright thanks I'll check into it. My luck I'd screw everything up
Take it to a pc shop they could do it for a reasonable price.
If you have the slightest pc skills installing a new OS is easy. I did my gpa's new Inspiron tower because he hates 8 even more than I do. I'd go to Dell's site and at least get their network driver before you do the install.
What happened to me, was I downloaded ALL the drivers for the computer from dell. Then I installed what apparently was a bad usb 3.0 driver, which interfered with the mouse and keyboard, so I couldn't click or do anything after the computer booted. It took me a while to figure out how to access safe mode because the preboot has changed a little. So I booted to safe mode (disables the drivers) and deleted the bad driver.
What I'd do is just get the network driver on a flash drive and once you load 7 on, go to dell's site and use the detection thingy to find and install the rest of the drivers for you.
Installing an operating system isn't hard, if you google it tons of guides will come up. All you really have to do is access boot settings and tell it to boot from DVD, save the settings, stick in the OS disc, power on/off and click next a few times, then let it do its thing.
I've been using a Gateway since 2012, great laptop that works flawlessly. Only thing I've done to it was add 4GB of RAM for a total of 8GB. Bought it from Walmart.com for $308. Will never buy HP again. Wife's laptop died after barely two years, and my HP desktop has been plagued with multiple problems.
  • 4 weeks later...
I have spent so many years wasting my money on different types of affordable lap-tops. I can say without a doubt that my macbook is better than all of them combined. The system takes a little to get used to but overall its the best thing you can do for yourself. You don't have to ever worry about viruses or issues making your computer slow. plus if you buy a mac care package, your computer will be insured for 3 years. even if you sell your laptop(which has an amazing re-sale value) the care package will go with the laptop.
Your mac book isn't as great as you make it out to be. The alienware is a very high end laptop made by dell that could easily outperform an apple. Also my desktop has an audio card thats at least 10 times more powerful than any APU that apple makes on computers, it even has swappable OP amps and a very nice amount of APU ram, it even uses real gold on the PCB board. You may like apple but the stuff is very cheaply made in mass production.
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
