2013 6.0L Resonator help...
Last weekend I installed a 3.5" in/out Magnaflow 22" muffler in place of the stock one on my 2013 Silverado 2500HD 6.0L. We welded a 3' piece of 3.5" 309SS from the muffler to the existing flange and behind the muffler we welded it up to the stock pipe. While I was at it, I gutted the resonator and now it drones terrible. Sounds awesome outside but in the cab is a different story. I know, I should have waited but I really didn't think it would have this affect. My question is now that I screwed up, what are my options to fixing it? Buying a factory ypipe section or welding a new resonator in place? Anyone want to trade ypipes?? TIA
Sorry....back to stock?
I love the sound of mine stock. Quiet at cruise and yet when you get on it it has a nice kind of growl.
Best part is that it cost me nothing.
ASAP - As Stock As Possible
Learned my lesson awhile back.
I think this is the first I've heard of a 22" being too loud. Most say mine is too quiet. Is yours a round muffler?
I didn't know they had a resonator on the Y, I thought all the had was cats. But generally gutting anything is a no no. Especially that far up.
Well on my 2005 1500 Z71 there was no resonator in the ypipe, just the 2 cats which I left alone and added a corsa sport catback which I loved. Instead of dropping 1k again on a catback, I added the 22" magnaflow (#12909). I think it would have been the perfect sound if I didn't gut out the resonator. I think stock ypipe is the way I have to go back or a Vibrant resonator welded in? In the Y, there are the 2 cats, 1 on each side and right after the 2 pipes join up there is a small 'bump' in the pipe which is right under the passengers feet that holds the resonator.
Oops. That "bump" ain't no resonator. Resonators are near the rear of the exhaust.
If you are talking about the 3rd cat looking deal that is at the end of the y pipe just cut it off and put a piece of pipe there. That's what I did with a magnaflow I think it's a 22" also.
That is what I am talking about .. this solved the drone in cab problem?
    d.lowrey
    d.lowrey
  • Who's Online   2 Members, 1 Anonymous, 3,233 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
