JDG24 2014 Build thread
jdg24
I picked the wheels out at dealer and had them order for me and put on along with tires and leveling kit. I asked what offset they are and he said they were 0 offset and I have no rubbing issues at all. So, I would probably go with the 0 offset. I am guessing you are going to at least put a level kit on? If not, you may have rubbing issues. Thanks for the compliment!
Thanks!
jdg, Truck looks great. I've got a 14' CC on order in the same color and I'm looking at installing the same tires (undecided on wheels). Now when I am on the Gear website the only two options for offset on the 6-bolt 18x9 are +18 and and -12mm.. I'm not saying they aren't 0 offset, but there's a good chance they are +18. Another thing that is confusing is that it looks like the Chrome 726 is available in 18x9 0 offset.
I've been researching a lot whether a 0 offset, 9in wide rim, and 33x12.50 will work without rubbing and I'm doubtfull. I'm thinking of going with a +10-12 offset then seeing if I have room for a 0.5" wheel spacer.
Please correct me if I am wrong! If can go straight for the 0 offset I will.
Source: http://gearalloy.com/wheels/726mb/#tbl_specs
I saw all of that also. I remember when I first bought the truck I asked him and he said it was the 12 offset. Later, someone on here was asking about the offset and I called back to ask what it was because I wasn't sure and that is when he said 0. This is what I went off of, his last statement. I never had a receipt to show what they exactly are because they put them on when I purchased truck. I don't think there is any way to know for sure. That's probably not helping you any, but that's what I know from what I was told. I was like you, originally thinking a 0 offset would rub but he said that's what they always use on the 2014's. Whatever they are the don't rub. :)
Thanks for the compliment and good luck with yours!
Toyo M/T 33x12.5x18, Gear Alloy 726MB Big Block wheels, Readylift front leveling kit color matched bow-tie, matching tint in front, Flowmaster 40 muffler
Awesome truck. Do you mind if I ask what kind of MPG you're getting running this tire/wheel set-up. I'm looking at similar set-up in terms of weight and wondering what the real world MPG people are getting.
Thanks
Thanks
I drive about 95% city and with 4922 miles my lifetime is 13 mpg. It usually shows upper 12's with city. On the occasion I drive highway it's anywhere between 14.5 to 22 depending on wind and hills. Thanks for the compliment. I have checked this with entering actual miles and gallons and the mpg showing on odometer is always within a tenth. Close enough I trust it.
  • 5 months later...
