Drive train noise help please
mississippi
im gonna try to give as much info i i can and see what you men think the problem is.
i have a 2000 chevy suburban 2500 4x4. here's the deal. when i drive down the road and the transmission has shifted out, at about 1500 rps or so i get a hard/loud vibration. sounds like i run off the road and hit the wake up strips..if i let off the gas it stops and if i give it gas it stops. it happens at the time the engine/transmission has the least load on it (if that makes sense) not going up or down hill, but say on flat road, cruise set and you try up increase speed just by pushing cruise control +. does that make sense??
also, when i pull something and the transmission gets to about 190 degrees it starts shifting really hard. does anyone know what is causing these 2 problems?
For the vibration/noise, try just touching the brake pedal, not enough to apply brakes, but enough to turn brake lights on. If your trans has the lockup converter, that will unlock the converter. It would be best to try that while it is vibrating. It will not prove the converter is the issue, since once the converter unlocks, engine speed will raise about 500-700 rpm, which may take the engine out of the range that the vibration occurs. It may not prove trans is bad, but it can prove it is not bad.
When all this fuel injection, on board computers and other high tech crap came out, I was told to not forget the basics. Always check the easy stuff first. Generically that means check plugs, wires, cap, rotor, filters, and fuel, before you start throwing parts at it, hoping something sticks.
Doug Scott. Thanks for the reply. Tomorrow I'm gonna hold it at the rpm it happens at and lightly touch the brake and see if that make it quit. I bet it does because any slight rpm change it goes away.
Does that mean its a possibility it's the torque converter??
Ill post back the results tomorrow
ok doug.. drove it this morning. let it shift out.. shifts out as smooth as always. while in 4th, running about 1500 rpm's it starts the hard/loud vibration. i lightly put my foot on the brake pedal while maintaining the rpm and it continues. i graduly push the brake harder and it continues until it shifted down to 3rd. for the next 20 miles. i could not get it to do it. i will add it does it worse when its cold, not as much once everything gets up to temperature
have a tech road test it ,,,,unless you can get audio or vidio with the help of a buddy and post back ,,,
13 yr old truck and the internet is a hard one to fix ya know
I had written a long reply last night, but did not press Post. I had asked if you could try using 3 instead of D to see if it happens when limited to 3rd gear.
If your truck is like my 2000 GTP, it would not lock up the converter until it was warmed up. I have found that if you are going to have a trans issue due to worn/leaky seals, it would be worse when cold. I think govtech4 is correct, it is time to get a technician to experience it.
i tried 3rd and yes itll still does it.. once it warmed up it dont do it anymore.. ill take it and let someone listen to it..i just hear these horror stories of folks taking it to places and never getting it fixed the first time and shops just swapping parts until something works. im one of those folks that if it need a transmission.... lets put one in it and be done... i dont like to change part after part and by the time its fixed... i could have put a new one in it ya know?? i was hoping it was something common on a 2000 model that mine just waited 13 years/130,000miles later to do!! LOL when i get the results i'll repost and maybe itll help someone in the future. thanks
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
