Transformations
SarahsGMC
I want to see them. All of them. I put this in the lounge because its more fun in here so no movin!
Found the old dealership pic that drew me into buying this lovely pile of red awesomeness so I made a comparison.
1002050_10202700919225141_1329442313_n.j
Chris I think you should of left the chrome fender flares on
One was destroyed when I caught a tree with the right bedside
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
