Best Method to Wire (4) Switches & Relays?
MotoMedic
As the title says, I'm trying to decide the best method for wiring four illuminated accessory rocker switches and relays, while also having all of them turn on/off with keyed ignition.
My thoughts so far involve using 5 relays...
Relay #1 - Input + from battery; on/off from RAP / keyed ignition; output + to the illuminated switches.
Relays #2-5 - Input + from battery; on/off from illuminated switches; output + to accessories.
Is there a better/simpler way..?
If I could only show you a matrix assembly from the f-16 lol. Your idea seems pretty good . I would think it better to use your method so you can isolate a relay if a switch stops working. If not, you could splice the positive output(s) together and use less relays.
Update: I've done many wiring projects in the past but never LEDs. Looking at my Carling rocker switches, they're rated for 10 amps each. Then I looked at my lights... max current that'll be pulled by any of the circuits: 3.8 amps. So, realized I'll only need one relay for RAP on/off then split to four switches. Sweet!
Thank you to everyone who commented.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
