Hi all, Aluminum knuckle question..
COW8OY
My Z71 CC has aluminum control arms and knuckles. I am wondering if anyone has tried separating the upper ball joint on these aluminum knuckles? (for strut removal for leveling kit) I always just beat the steel ones till it popped out, thinking this would not be good idea on the aluminum. :-/
You need to get yourself a pickle fork / balljoint seperator.
^^^^ just becareful not to tear the boot if you use this... I like using those if im replacing the ball joint. have you seen the knuckle are you sure the knuckle is alum? I thought only the control arms were alum. either way seeing how there is a lot of weight that bears on those knuckles I am more than positive you would be ok to hit it a few time with a BFH. since these trucks are still knew it should not take a lot of force to get the knuckle separated from the ball joint. now if you have had the vehicle a few years and drive in the road salt then things might be different.
I have a fork, trying not to use this as Iam not changing the ball joint, and they inevitably tear em up. I was hoping someone had experience with the aluminum knuckle. I did rap on it a a bit, but the difference in metals seems to make the knuckle grip it pretty tight. Going to try some heat tomorrow. Thanks for the replies.
Well, if the CV axle is as easy to remove on the 14s as the earlier models I'd go ahead and remove it and try
Do not use a pickle fork and do not use heat. A simple rap on the knuckle will pop it loose just like it did for the steel A arms. We've had aluminum A arms on the Corvettes for years and this is how we've always disassembled them.
I have taken mine apart. I used an air hammer with a flat hammer tip. It took about 5-6 blows and they popped right out. No damage done to aluminum at all. I would also not recommend a fork.
Thanks, I will try this. I never use a fork unless I am done with the joints.
I tried quite a few raps, wasn't wanting to try much harder. Thanks.
My '14 has the aluminum a-arms and spindles, and I did my leveling kit about a week ago. I used a hammer, no heat or fork. After hitting the drivers side a few times with no luck, I gave up. As I was walking away the ball joint popped all on it's own. The passenger side took more effort, maybe a half hour of on-again, off-again hammering. But I got it done without heat or a pickle fork. The hammer did mark up the surface of the aluminum a bit, but nothing major. I like the idea of using an air hammer, wish I would've thought to use mine.
