Qualifying
General Lee 01
OK, qalifying is over.
Jeff Green grabbed the pole and Jr. grabbed the outside of row 1.
So much for my prediction of the chevys having problems due tothere-design. :D
I estimate Dale Jerett to start whineing before to long...... :crazy:
ding ding ding.  we have a winner, I mean whiner.  Just watching the rebroadcast of qualifying and Dale J is doing his job of crying for their Fords.  Get out there and test and quit blaming your shortfalls on everyone else.  geez I'm tired of that.  Like they were saying tonight.  Look at the TEAMS in the top 10.  It's called teamwork.  Not car manufacturer.  Nascar has determined that they are as "aero identical" as possible, so what does that leave?  Engines?  Gearing?  Teamwork?  Get with the program Dale.
:smash:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
