Can anyone ID these rims?
skarekrow
Link worked fine for me. Not sure what the confusion may have been.
Unfortunately, I don't recognize those wheels.
yeah, they definitely seem like BMF's with those dots on the outer edge, but they aren't sota's, and I don't see them on their site, maybe they are a discontinued model
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 699 Guests (See full list)
