oil usage??
any issues with GM's using oil because of the FMS? someone was telling me the cylinders fill up with oil when the FMS kicks on? first i'm hearing of it. also said the aluminum block is no good for other reasons.
I didn't have any. some guy here at work has a GM. He was telling me this. I figured if anyone had issues, we'd see them here. I was just checking.
You have 150+ posts so you've been here more than a day. Pinned to the very top of this forum section is a thread specifically about trucks using oil and it is over 30 pages long. Been there for a couple years.
I just don't understand the mentality that you should never have to add oil..... a quart per thousand miles isn't too much to ask.... the quick lube here (I don't use them but still) will top off for free in between changes within reason....
So your are saying it's perfectly normal to have to add oil in between changes on any vehicle?
Every owners manual I've seen has some range for oil loss between servicing. Between all the complex stuff oil has to do these days and the long service intervals I can't say I'm surprised.
A quart per 1000 miles not too much to ask? Hell, I have owned several semi truck diesels with engines from 12.7L to 15L that if they used that much it would be way past time for an overhaul. My present factory rebuilt 12.7L Detroit (also known as "leaktroits"), doesn't use a quart in 15,000 mile oil changes. Really difficult to imagine a 5.3L engine using a quart in 1000 and considering it "normal". A 454 V8 I had in a '98 2500 didn't even use a quart in 4000 miles.
That being said, because I disabled the AFM on my 5.3L from the moment I brought it home new, and I installed an oil separator catch can on the PCV, it is typical for my 5.3 to use 1/2 pint in 6000 miles. That is more like it.
Unacceptable IMO, guy spends $60k on a new truck up here in Canada. Buy a truck that burns oil? Lol...I've stated my views on this in a couple threads. I for one think it's ridiculous.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
