Audio processor
Hey all, recently upgraded the sound in my 2014 silverado ( components, amps, sub) now looking at adding a processor to clean things up a bit. I have a good ear for sound but no real experience with tunning a system. I was looking at the jbl ms8 for ease off use but not sure.
Any body add a processor to their 2014 yet. What did you choose and why?
Id be interested to hear the difference with and without one. The guy at the audio shop said they're not as effective with newer equipment.
interesting i had not heard that.
my stereo install shop told me the same. They said the sound processing in my JL hd900/5 was more than capable of handling it.
While the JLhd900/5 is an awesome amp, it is not really capable of doing processing, just crossovers. need something like an audio son bit1 or bit10, jl cleansweep, fosgate 3sixty, audio control, etc
  • 2 months later...
If you don't mind me asking.. What components did you add?
  • 3 weeks later...
I have a JBL MS-8 in my 2009 GMC Sierra Denali. But I have gone full aftermerket. There is nothing from the original Bose system left in it. Everything is run active off the MS-8 and sounds great.
:withstupid: Or a JBL MS-8.
Here you can see the JBL MS-8 processor next to the JL Audio HD900/5 amp.
or that too :P
:D
I added a Jl audio cleansweep with a Jl audio signal summing interface. I am running 2 arc audio amps(1200 watt subs 500 watt mids highs) and focal mids and tweets with massive audio subs.While the sound is definitely better than factory, it is still lacking the sound that my alpine INA w910 put out with same setup. Thinking about trying the fosgate 360.3 but it is expensive!
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
