4 Days with BK Racing & Borla in Daytona Beach
ATTENTION RACE FANS! Borla is about to launch a sweepstakes for the racing vacation of a lifetime! The winner of our "4 Days with BK Racing & Borla in Daytona Beach" promo will get airfare for two, five nights lodging, a rental car allowance, two VIP BK Racing Access "Hot Pass" Credentials to the full weekend in Daytona Beach, FL, Feb. 20-23. You'll watch the Borla #83 BK Racing car take its shot at glory and get to meet driver Ryan Truex. Oh and we'll even throw in %50 off a Borla exhaust system. We don't have much time, and the sign-up form will be posted on our website, so stay tuned to www.borla.com!
Lindsay Lombardo
805-986-8600
Borla Exhaust
www. borla.com
  • 3 weeks later...
An unusual turn of events adding to the drama of this first race of the Sprint Cup series switches the second BK Racing car — Alex Bowman driving car 23 — to be transformed into the Borla Exhaust car for Sunday!
Rookie Bowman has qualified to start in the 15th row, 30th position out of 43. The 23 car will be rewrapped to sport the Borla Exhaust red/black/white colors and exhaust graphic scheme!
What brought this about? BK Racing's 83 car, driven by rookie Ryan Truex and sponsored by Borla Exhaust, was involved in the big wreck in Wednesday's practice run.
The team was able to prep their backup car just in time for Truex to run in the second Duel's 60 lap qualifier on Thursday. There was no way for Truex to get any seat time.
Truex got up to the 19th position when, in the last corner of the last of 60 laps to qualify for Sunday, Jimmie Johnson's car ran out of gas, triggering a spectacular 7-car crash, putting an end to the race with just a half lap to go.
A testament to the rookie's driving skills, Ryan was able to avoid involvement in the mayhem on the track, wiggling his way around to prevent any damage to the car.
Unfortunately, when the official results were announced, it was learned Truex did not make it on the bubble, dashing his hopes for a spot in Sunday's race. But Phoenix is only another week away.
Lindsay Lombardo
805-986-8600
Borla Exhaust
www.borla.com
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
