Wraps are nice, but for the long haul, go with paint. If you are going to be car less, they have cheap rentals. GL
Not sure how close the color ACTUALLY is, but I just very recently got a 2016 Silverado 1500 LT Z71 in the Autumn Bronze Metallic and I absolutely love it!
Now I just need to start saving up for a cover, fender flares, RC leveling kit, nerf bars, etc.
Hey what's up guys and gals? I'm new here and wanted to see what you guys think about my truck and what's been done so far (not much) and prospective upgrades in the works as I type. Please give me some feedback. It's great to finally find a group of people who like this color on these trucks! Ok anways here goes.....
2015 Silverado 2500HD Duramax 4x4
Leveled (left some rake for towing my camper)
275/70R18 General Grabber AT2
American Racing AR708 18x9 +20mm offset
Duramaxtuner SPADE tuned
Prospective Upgrades are
Iron Cross or Road Armor front and rear bumpers
The new mirrors off the 2015.5 models
And black fender flares
Edited by D-Train251
attachicon.gif12715667_10208956840628330_8859757326143276775_n.jpgWho says Brownstone cant be bad ace
I dig brownstone (was my second choice) but did you know you have purple headlights? Purple and "bad ace" can't be used in the same sentence... Otherwise, pretty sweet setup!
Tyler
I can dig it. Do the lights chance colors?
Hey Brother yeah these are the oracle RGB color changing i usually run amber to avoid tickets here in VA pain in the but to install but well worth it
Tyler
Hey Tyler yeah i thought i hit the red button to make it evil and wala this is what my daughter made it when i snapped the pic lol
That just looks great.
Awesome looking truck.
Thank you
Tyler
This is for you Tyler lol
Have you seen the Hammerhead bumpers that's what I will eventually go with. In my Opinion only Iron Cross give a nice smooth look road armor looks more aggressive
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,189 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
