SEATTLE SEAHAWKS
Squirrely
I agree. Young team... they should be contenders for a while.
It was just a trip to watch this game and think about preseason. I remember my Denver friend saying that didn't mean anything. Hmmm, really....
Damn the hawks looked good last night! No BS calls, no nothing, just pure dominance.
What also was nice the refs let them play,no BS penalties.The refs did a good job,unlike a few years ago.
They will be good until the HUGE market teams start signing the free agents to MEGA buck deals.
Even though I'm a Denver fan I gotta give credit to Seattle. Those boys showed up to play some ball. Good job hawks.
Sent from my LG-D800 using Tapatalk
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
