3M or Equiv Clear Film Front End Protection...Options?
The first car that I had the 3M installed on was my 2006 C
harger with the metallic three-step ToRed paint, which I think is as bad as black, and I sold the car to the guy who does my service work and it still looks as good as new! I have had the 3M on a silver Denali and now on two white-diamond Denali's and have nothing but good to say about it on these three colors. The only people that I have heard knock the 3M, is people that either sell something else or have never "owned it!"
I'm just giving from my experience. We installed 3M a few times. But replaced existing 3M for xpel more often. I'm not selling anything I don't even work for the shop anymore. IMO there is a better product and I was just giving my advice since I was on the "supplier" side of these products and saw results and finishes more often than a normal consumer.
  • Replies 34
One mistake that many people make is that they think that since this part of the car is covered in "plastic" they don't have to wax this part. Big mistake! Whenever you wax your car, be sure and wax the "complete" car. The front even needs waxing "more" often. Makes the bugs and road debris much easier to remove. I always wax the front of my vehicles before we take a trip!
I didnt see this thread until now but I have my entire GT500 covered in Xpel Ultimate, worth every penny! Why because my car doesnt have a mark on it. I just got my Denali and have an apt with my Xpel guy already for the Entire front to be done to include the headlights. Xpel's self healing quality and tight fit for an OCD guy like myself is the ticket. I spent good coin on my Gt500 and will do so on my Denali even if I only keep it 4 or 5 years. It will look badass for the entire time. I had 3m many times on a few BMW's, it looks like shit on black it really does, my Xpel on my Black Gt500 is perfect you cannot tell at all it is there unless you put your face sideways on the hood. My .10 cents is buy Xpel never look back and then take a grill brush scratch it up and pour hot water and impress your friends i do it all the time its funny.
This. We did scratched the hell out of a BRAND NEW 911 Porsche that had xpel at the houston auto show, peoples eyes almost popped out of their head!
  • 3 months later...
I am finding that as I get out of my truck - especially at night - I find my feet sliding along the bottom of the door jam as they look for the step side and it's leaving some scuff marks on my nice black paint. Would Xpel be the best thing to use there as well?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
