HID Projectors Retrofit for Silverado LS/LT
White14
Ya you would have to retrofit them. I use to do tons of retrofits, you basically bake the headlight in the oven to loosen the glue then you can pull the lens from the housing.
From there you can do pretty much anything you want inside the headlight. Paint, LEDs, Halo Rings, Remove Yellow signal lens, etc.
It's really not that difficult once you get the hang of it.
