No 4low and transmission slipping?
My 03 2500hd with new motor is having last two issues.
One
Won't go into 4low and yes it's in neutral when I hit it. It blinks and goes back where it was.
Also
When shifting to 2nd unless I Matt the gas it seems as if went into neutral mid shift revs up and slams into second if i don't let off. Could this be because of new fluids?? It's also a bit over the fill line. Do I need a trans now?
Thx
agreed ,,,scan the TCCM
oil over full slightly does not make a tranny slip or new fluids
have the PCM scanned while your at it and report back ,,,,,
what is t case oil level and condition ?
I have a code reader and a tuner both show up with nothing.
t-case are good and new. I just took it apart to do the (t-case fix) before it gets a hole in it when I had the motor out. I filled it up till fluid came out of the fill hole. also 4low was working in the beginning and now its not.
the tuner actually seemed to clean up the shifting a bit.
It can't read Tccm codes I believe
Please explain the Tccm? Also I am looking at $2400 for a trans that's fairly built? Seem reasonable? Shop said I gotta bring it in and they rebuild it. If that's what I have to do.
Transfer Case Control Module
on top of that ya got to pay to have it removed and installed ,,,,,7 hrs labour ,,,cooler flushed also
you're looking at $3100 (if the shop door rate is $100)
alot of money and ya get a year warranty ,,,,for an 11 yr old truck ,,,your call bud
maybe 5 hrs labour ,,,,i cant remember lol
I was told $85 an hr.
and I supply parts
all from summit
high performance over haul kit. high performance clutches Kevlar bands
hardened out put shaft
billet clutch hub
shift kit
and a performance converter. not sure what stall was looking at 1500.
that comes all out to$2400 if I bring him the trans.
cant I flush my own cooler?
sure ya can , you can use brake cleaner and push it thru with air ,,,,
or varsol
you'll have to have the shift adapts reset by a scanner that is capable of that function ,,,,,,
my road test after a rebuild went like this ,,,,,,
fill tranny to full cold ,running ,,,
pull away taking it easy ,,,go down to thru the gears and back up to D4 (not hitting highway yet ),,,off to a highway ,,,get to speed limit slowly ,,,go about (miles conversion) 7 miles ,,,turn around ,,,,put the hammer down(at least 3/4 pedal) to max out each gear to speed limit ,,,,,also make sure up shifts(passing gear) works along the way ,,,
get back to shop ,,,check level ,,,should be near full hot mark ,,,,,,check for leaks ,,,,,
IF ANYTHING DOES NOT WORK OR SES LIGHT COMES ON RETURN TRUCK TO BUILDER !!!
reset shift adapts BEFORE road test
if he doesnt offer a warranty ,,,,,stay clear of the tech/shop
or varsol
he offers a one year or 12 thousand even if I supply parts.
or I found a new remand trans $1300 installed one year warranty
soooo built up or stocker? that's where I am at and my tcase is pissing me off. I want to climb snow mounds but not in 4hi....
also I am trying some lucas stop slip today. I checked fluids and im pretty over... so gonna dump it out some and put in lucas. pretty sure its cuz the trans is worn and lucas should help it a little. got George strait concert today.
GM has 3 yr/60Kwarranty on their rebuilt trannies ,they have a nice cooler flushing machine they have to use as well
George who ? lol
  • 2 months later...
well I took it to bob at godfather racing. he rebuilt it and got me a tq converter. he did a fine job! nice and smooth. only have one problem still.... no 4 low!!!! is there suppose to be a green light on the switch panel when you put the truck in neutral because mine not lighting up and it could be that its not reading that it is in neutral? any way to test it?
Most scanners won't pick up TCCM codes. You may end up having to take it to a place with a Tech 2 scanner (dealership or otherwise).
Is that right Rob?
Is that right Rob?
yup or a good snap on scanner just not a POS code reader that typically reads engine codes only .lol
remember ,there are only 10 or so modules on todays drive by wire veh's that love to barf out codes lol
    small navy
    small navy
  • Who's Online   5 Members, 0 Anonymous, 829 Guests (See full list)
