No 4low and transmission slipping?
yup or a good snap on scanner just not a POS code reader that typically reads engine codes only .lol
remember ,there are only 10 or so modules on todays drive by wire veh's that love to barf out codes lol
its not just a plain code reader. it was fairly expensive and gets into some detail. ill post the name tomorrow after work.
  • 3 weeks later...
Ok. So I don't want to pay the dealer just to say I don't have any codes... I would rather have a list of possibilities and go down the line.
I was at silver lake sand dunes this weekend and not having 4low sucked...
Also should the light "N" on the 4wd buttons come one when the truck is in neutral? Because mine does not. Also the line that goes under the P R N D 3 2 1 jumps around a lot and sometimes doesn't show up or says I'm in N when I'm in drive.
Another thing that happened this weekend was the truck wouldn't go into park something in the linkage in the steering column was holding it up. But broke free and was able to go into park. But now when I wiggle the shifter back and forth it's sloppy.
Your shifter cable end at the tranny is most likely broken where it clips in the bracket hence the inaccurate gear and no park complaint ,off roading does this on a regular basis,
I told you to get the TCCM scanned for a reason , find a garage (doesn't have to be a dealer ), that has a scanner and pull the GD code already ,
Reply with that code #
i found a place that does ut around here. they charge $60 for the scan. so Ill get back to you when I get the money to fork over.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
